08-23-2018 05:26 PM - edited 01-05-2022 12:38 AM
Hi - I'm looking at buying an inexpensive phone for my kids to use on PM. One I'm looking at is the Motorola Moto E5 and I'm wondering how I confirm if this phone will work on the PM network. I know that PM has a feature on their website where you can confirm compatibility, but you need the IMEI of the phone to do this and I'm not sure how I do this if I don't yet have a specific phone. Does anyone know specifically if the Motorolo Moto E5 will work? Thanks!
08-23-2018 08:54 PM
Friend just purchased E5. Works fine on Public Mobile.
GC
08-23-2018 05:56 PM
Is this your phone that you are interested?
https://www.gsmarena.com/motorola_moto_e5-9008.php
If it is the phone, it should work since it covers the following
Public Mobile works on following frequencies:
08-23-2018 05:56 PM
@Alejandra wrote:Hi - I'm looking at buying an inexpensive phone for my kids to use on PM. One I'm looking at is the Motorola Moto E5 and I'm wondering how I confirm if this phone will work on the PM network. I know that PM has a feature on their website where you can confirm compatibility, but you need the IMEI of the phone to do this and I'm not sure how I do this if I don't yet have a specific phone. Does anyone know specifically if the Motorolo Moto E5 will work? Thanks!
On the motorola.ca website the E5 Play has the following bands:
4G LTE (Cat6), CDMA / EVDO Rev A, UMTS / HSPA+ GSM / EDGE
4G: TDD LTE band 38/41(Full) FDD LTE band 1/2/3/4/5/7/8/12/13/14/17/25/26/29/30/66
3G: WCDMA band 1/2/4/5/8
2G: GSM band 2/3/5/8 CDMA BC0/BC1/BC10
It's pentaband 3G and has band 4 + 7 on LTE so you're good for Public Mobile.
08-23-2018 05:49 PM
Don't use the Public Mobile site for that. The compatibility check feature of that is next to useless. Instead, make sure yourself that the phone specifically has at least UMTS 850 and 1900MHz (umts bands 2 and 5).
08-23-2018 05:48 PM - edited 08-23-2018 05:50 PM
Hi you can use this website:
Do you have the specific model? Can google it to check if it has the necessary LTE bands. It will work on 3G but I think theres 2 versions although I believe if you bought it in Canada it should work on LTE on PM.
