More than 1 data add on
Dninclaus
Is there a limit to the data add ons you can buy ?
srlawren
@Dninclaus please note @NDesai raises a good point that it makes a difference if you are talking about US Roaming data add-ons or the regular domestic ones.  As @Anonymous noted, I don't believe there is any limit on the domestic (non-roaming) data add-ons.  I remember a while back seeing someone in the community whom had purchased--I believe--12 of them at once and had them all stacked up and waiting in case needed.  That scenario never made sense to me, and I think that if you are in need of more than a few a year, you definitely would be better off looking at a different plan as $30/GB is much more expensive than plan data.  If you need more than PM offers in plan data, you may want to look at other options elsewhere.
NDesai
Not sure on the max limit, but you can purchase more than 1 CA data add-ons. If you buy 2, it will say you have 2048MB available to use. This can't be done with the US roaming add-ons as there is a 10 days expiry limit.
Luddite
Do you mean simultaneously? What purpose do you have in mind?
Don't think there is a limit.  However, it usually isn't cost effective to do that.  Would be cheaper to change your plan to include more data.  The addons are generally much more expensive than adding data to a plan.
