01-06-2024 05:30 PM
I bought the 100 minutes world wide canada talk,I'm sure I have'nt talked for 54 minutes but this is the usage that shows on my profile.I had this plan before and had the same problem.Can anybody help with this problem please?
01-11-2024 12:12 PM
After about 5 days,I did not receive any help from customer service.I'm not sure if there is a customer service section.
01-07-2024 06:11 AM
No,not yet.I checked my usage history and it's indeed a miscalculation.Unfortunately this is a second time it happens for me.
01-07-2024 04:06 AM
Have you been able to get help/fix your problem? Was it indeed a miscalculation from PM's systemn in the end? Maybe I should watch my minutes more... :S
01-06-2024 09:29 PM
The 100 minutes is for outgoing calls only and is not deducted for incoming calls.
It minimize your outgoing calls. Just text (unlimited) your family and friends to call you or use WhatsApp for free calling and texting over wifi.
01-06-2024 06:02 PM
I will do. I really appreciate your help and thank you so much
01-06-2024 06:01 PM
hi @afsanehvarasteh we are just customers like you and we have o access to your account to confirm. Yes, discuss with support agent and they can check the usage again
01-06-2024 05:52 PM - edited 01-06-2024 06:06 PM
I checked and I did not talk for 54 mins
01-06-2024 05:42 PM
hi @afsanehvarasteh login to My Account, click usage history and check the outbound minutes one page at a time (please be aware that the download feature does not work, it won't download all usage)
and as said, submit ticket with CS agent if still in doubt
01-06-2024 05:41 PM
@afsanehvarasteh In your account overview page you can also check your usage do you maybe have one call that went on longer then you realized or possible pocket dialed someone
01-06-2024 05:39 PM
Thanks for reply. I did that and still shows the same thing
01-06-2024 05:35 PM
@afsanehvarasteh PM also has cache issues check in your account like this in case you seeing old info
Try again incognito/private mode
And or lap top /computer
OR
simply try refreshing the page to check data plan / mins / add ons
01-06-2024 05:35 PM
Thanks.I'm sure I haven't talked 54 minutes.I was in hospital and really did not have many calls
01-06-2024 05:35 PM
You can message the customer support here here https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
It might be a bug you can try to clear your browser cache or incognito mode if it still say 54 minutes of usage
01-06-2024 05:33 PM
No I didn't check that.
01-06-2024 05:32 PM
@afsanehvarasteh Are you checking your voicemail often ? It will count against your 100 out going mins
01-06-2024 05:32 PM - edited 01-06-2024 05:32 PM
hi @afsanehvarasteh remember all tk minute usage will be billed by rounding up to the next minute. A 1 minute 1 second call will be 2 minutes usage
if in doubt with you usage still, please submit a ticket with CS Agent here:
