Monthly data totals
DDM69
Is there a way to view my total data usage in previous months?  I do check my usage occasionally during my current month, but when I look at my usage history, I can only view day by day usage totals.
Is there a summary page I am missing?
Thank you 😁
DDM69
Yes, I did mean cycle.  I've downloaded the file, now just trying to make adjustments to filter the data.
Thank you @dust2dust & @softech 😁
DDM69
That works.  Thanks
@DDM69   not for current "month" but current "cycle"
PM's overview page show the data used for the current cycle
if you want a data tracking for current "month", you can do so on Android phone, build in data tracker.
Or you can use app if you have an iPhone
Not sure if download work now, you can also download your usage history and add it up using Excel (the download link is on the top right of your screenshot, but download didn't work earlier, not sure if they fixed it yet)
dust2dust
Don't use filters. See that little download link in the upper right. That will produce a spreadsheet file. Then you can massage the data all you like in the spreadsheet.
