@Moderator_Team
06-22-2019 02:08 PM - edited 01-05-2022 05:31 AM
06-22-2019 02:30 PM
@OvidiusMaximus ok well hopefully they will contact you soon it shouldn't take more than 2days most times its alot less than that I know its alot quicker in your account under change phone number
06-22-2019 02:26 PM
I contacted them through through private message
06-22-2019 02:25 PM - edited 06-22-2019 02:27 PM
@OvidiusMaximus I must ask how did you contact the moderators in private message or just by tagging them like this time?
06-22-2019 02:22 PM
@OvidiusMaximus wrote:I have tried all that. Contacted moderator team and no one is answering. this was two days ago
Don't give up they will answer and help you!
What exactly doesn't work? Did you try with a different browser or on incognito mode?
06-22-2019 02:20 PM
06-22-2019 02:17 PM
Here is info about porting. If you need assistance then contact a moderator.
https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
06-22-2019 02:15 PM - edited 06-22-2019 02:15 PM
@OvidiusMaximus wrote:Please help with porting phone number over to pm
If you are porting a Koodo prepaid number, send a private message to moderator to port your number.
Otherwise, your can use the self-serve portal to port your number to PM.
[Plan and Add-Ons]--> [Change Phone Number] --> [Transfer a wireless or wireline number ]
06-22-2019 02:14 PM
@OvidiusMaximus wrote:From Sasktel
Did you try with the self-serve? Tab PLAN/OPTIONS and CHANGE MY NUMBER?
06-22-2019 02:13 PM
From Sasktel
06-22-2019 02:09 PM
Yes what's your problem? Which company?
