06-25-2019 04:58 PM - edited 01-05-2022 05:34 AM
How can I reset my 4 digit pin .. I added $43 dollars it's on my account and I'm still suspended
06-25-2019 05:33 PM
To reach the Moderators:
You may also click on the little envelope at the right of the little bell, upright page.
06-25-2019 05:02 PM
@Bohnenschuh , resetting the account PIN requires moderator team support. The moderator team can be reached via private message using this link. Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
06-25-2019 05:00 PM - edited 06-25-2019 05:01 PM
@Bohnenschuh wrote:How can I reset my 4 digit pin .. I added $43 dollars it's on my account and I'm still suspended
@BohnenschuhOnly the mods can reset your pin. (Although I have heard a trick where if its the same as voicemail pin you can reset your pin by resetting your voicemail pin? But I don't know about this ((login to your account and click Reset Voicemail Password)))
Are you not able to log into self serve using your email (username) and password?
