01-05-2023
07:15 PM
01-06-2023
05:35 PM
computergeek541
01-06-2023 05:56 PM
It really sounds like your account has been deactivated. Another thing to try is using another phone and dial 1-855-4pu-blic and entering your phone number. If it comes back saying invalid then it's gone.
01-06-2023 05:54 PM
Mobile not registered with network no any cell phone signal bar showing on the phone, and 4 months ago I paid it. When I call to my no number I am getting responses " The no you are trying not in service ".
01-06-2023 05:47 PM
@julan when was the last time you used PM service? Account suspending for non payment for over 90 days will be closed
Was it that long?
01-06-2023 05:40 PM
You didn't answer my question. When did you last pay? Or also what recording do you get when you dial 611 with the Public sim in the phone?
01-06-2023 05:38 PM
Actually my old sim belongs to public mobile network, I want to activate it again since that no very important for me thats why, how can I get it back, could you help me by steps.
01-06-2023 05:34 PM
When was the last time you paid? If more than 4 months ago (120 days) then the account is gone.
If you wish to be with Public then you'll need a new sim and create a new account. If your number originated from here (or Telus or Koodo) then maybe you could get it back. But if it came from a whole other provider then you would need to go back to them to get your old number.
01-06-2023 05:26 PM
4 months old sim it's not in service now, I want to activate it again I checked by calling that no I got response that number not in service, could you please help me how to activate it again.
01-05-2023 08:30 PM
HI @julan did you join PM just now and unable to use the network?
or you are exiting customers?
Did you try to use another phone to test?
did you check My Account and account is showing active?
give us more information so we can help
01-05-2023 08:06 PM
@julan - are you a new customer, or a customer that has had working services all along until 'all of a sudden'?
Try your SIM card into another compatible phone, if it works, then check to see if other phone is compatible or if it is blacklisted.
Frequency checks:
https://www.kimovil.com/en/frequency-checker/CA
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
01-05-2023 07:44 PM
Try turning the airplane mode on and off a few times. Waiting a few minutes in-between on and off.
That usually fixes that situation.
01-05-2023 07:21 PM
@julan Try turn off the phone, then remove sim card, wait a couple of minutes, inset sim card, reboot the phone.
Check your phone APN settings:
01-05-2023 07:19 PM
01-05-2023 07:19 PM
Turn phone off, wait a while, turn it on.
Check for service outages:
01-05-2023 07:17 PM - edited 01-05-2023 07:30 PM
