12-23-2022 01:56 PM
I'm getting constant issue making/receiving phone calls. When I try to call I get "mobile network not available" and the call won't go out. People call me and go directly to voice mail (which later I cannot access because of the 1st issue 😞 ). Data seems to be fine. I have to use wifi and whatup for communication.
I already tried turning my phone off/on and resetting all.
What is happening with this network?
12-24-2022 10:32 AM
Thanks, seems to work, however, it could be temporary as changing to 3G will make data very slow. Hope to make calls can be done again as it was a couple of days back using 4G.
12-23-2022 11:00 PM
There could be an outage in your area.
Check outage mail:
12-23-2022 03:58 PM
the fact that data works but not voice might mean there is a problem on the 3G network in your areas as voice can travel on 3G only with PM.
Try to reboot the phone first
if fails, try to change to 3G network to see if it connects at all
Weather is not an excuse, but it could be a fact causing the problem. I had some text issue earlier today, reboot does not work and I have to change to 3G network for it to work.
12-23-2022 03:53 PM
I don't think that weather is a valid excuse for lack of service !!. Meaning that I will need to look for a company that is reliable during winter?
12-23-2022 02:02 PM
@fdocruzs @Could be the weather right now , otherwise I’d try contacting a agent for help
