12-24-2022 10:52 AM - last edited on 12-24-2022 10:57 AM by computergeek541
12-24-2022 11:05 AM
@Clinteastwood did you get the txt msg from PM? or you can submit the ticket to CS_Agent about the bonus gift
12-24-2022 10:58 AM
If you are old customer (before Dec 1) and you did not get SMS from PM, try to send SMS YES2 to 4911.
If you are new customer bonus will be automatically added to your account.
But I would suggest to contact agent, that will be fastest to add bonus.
To Contact CSA-agent; there are 2 methods:
Ticket has to be opened through chatbot - https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking (Ctrl+)Here
12-24-2022 10:54 AM
@Clinteastwood First try texting YES2 4911 if that won’t work you can contact a agent and the y will apply it for
Contact an agent:
