02-02-2024 03:15 PM
Ever since switching to public, mobile hotspot does not work, worked fine with other carriers previously. Same devices.
I’ve submitted questions about it but no response for months
06-10-2024 10:59 PM
you sure the APN was showing sp.mb.com? Many had it for isp.mb.com and that was the reason it was not working. Also, make sure to leave Username and Password blank
and of course, make sure iOS is updated and get the latest Carrier Profile
06-10-2024 10:57 PM
Thanks ive done all of this but hotspot hasn’t worked since day one with public mobile. Iphone 12
02-02-2024 03:36 PM
start with Reboot phone and Reset All Networks
for iPhone:
Settings > Cellular/Mobile Data > Mobile Data ptions > Cellular (or Mobile Data Networks)
In the Personal Hotspot section, make sure APN is set to sp.mb.com
For Android, check APN type, try both below as it could be case sensitive
APN Type: default,supl,mms,dun
APN Type: default,supl,mms,DUN
02-02-2024 03:17 PM
@Nateklein PM does not block hotspot
iPhone or Android??
