06-09-2026 10:04 AM
06-09-2026 12:32 PM
Yes. Thank you.
Daniel the CS_agent was able to fix the issue and fast. Very professional
Thank you guys for your help
06-09-2026 11:00 AM
hi @Momma1
you might need to ask PM agent to refresh the account
submit a ticket with CS Agent using Chatbot here:
Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
06-09-2026 10:56 AM
@Momma1 wrote:what phone you have? Android
did you check Telus Outage site? Yes
https://www.telus.com/en/bc/outagesdid you try Reboot phone and click Reset network settings? Yes
Still not working
if you use the old sim card, can you remove it and try it in a different cellphone to see if it'll work ? That way, you can tell if the issue is because of the cell or the sim. Ignore my suggestion if using esim though.
06-09-2026 10:41 AM
Still not working
06-09-2026 10:19 AM
log in to your Public Mobile account and make sure you still have data available for use...maybe you've used all your data allotment until next regular plan renewal occurs.
06-09-2026 10:12 AM
hi @Momma1
what phone you have? did you check Telus Outage site?
