Mobile data internet is not working
Linaanata
I just made renewal payment for my sim card yesterday, and chose data plan as well. However, I am still unable to use mobile data (for internet browsing) until now. As additional information, my previous package will be expired on dec 8, but I make a payment earlier so I can still enjoy my data plan. Does anyone know how to solve this problem? Thanks in advance 🙏
8 REPLIES 8
YVR
@Linaanata
Public mobile has a FREE 1G add on right now. This can be used so you have days after you use to your plan data.  They also have 400 intentional calling minutes
YVR
@Linaanata wrote:
Yeah, i have tried to reboot my phone, but nothing's changed.  I will wait until dec 8, and hopefully be able to use my mobile data as previous.  Thanks for your advices
Did you check in self serve.  Maybe your mobile data for the 30 day cycle got used up.    Yes, you will be reset on Dec 8 and can your data again.
You can also buy a data add on so that you can still use data when you are over your monthly plan usage.
You can tell if you've used all your data by looking at your overview page lower down under add-ons. If you don't see a data line there then you've used it all. Or post a screen snip of your overview page and we can help you figure out what you have. Blank out personal info of course.
Meanwhile, your options are:
to ask the moderators to renew your plan early
buy data add-ons
change to a different plan now
Linaanata
srlawren
@Linaanata if you literally *made a payment* only, then nothing will have changed with your plan.  If you scheduled a plan change for your next renewal date on Dec 8th, then you won't be on your new plan until Dec 8th.
@Linaanata wrote:
Yes, the mobile data was working well before and i dont have any issue with apn, i guess.  I did changes to my plan because my previous plan seemed didint work..
Is it working now?  What do you mean your previous plan did not work?
You can try rebooting your phone.  Usually after making any changes it's recommended to restart your phone.
Linaanata
Has data ever worked on your phone? If not, this could be an APN setting issue.
if the data did previously work, am I correct in assuming that you did an immedaite plan change to get data working again after running out from your previous plan?
