3 weeks ago
Hello Community, @fixin1 here.
You may currently be experiencing a major network failure of wireless services in Western Canada. Calls and SMS messages will continue as normal.
It is labeled as a Hardware issue, likely in the core network of the Western Canada server, https://productioncommunity.publicmobile.ca/t5/Get-Support/Network-sharing-explained/td-p/129092/pag...
I live in Alberta and am not currently experiencing it, so it might also be a RAN issue on a number of towers at once.
https://www.telus.com/en/bc/outages
There is another outage of cellular due to a fire located in the Montreal (Mount Royal, Outremont), Quebec region. It will affect ALL things like Data, Cell calls, and SMS messaging.
3 weeks ago
@hTideGnow - Yes, it might just be in Manitoba, but must got reports from people all over Western Canada.
3 weeks ago
