Missing referral code
CBF1
My referral code isn't being generated.
I clicked on the "share the love" area and got this for my link:
https://publicmobile.ca/en/bc/plans?referral=
CBF1
Thanks - it's magically showing up now
Brianna182
Oh this happened to me too when I was trying to refer my partner! I was so confused. The referral code picture didn't show up either so I was like ??? If you're on the app, try looking for it on the browser or vice versa. That's what worked for me. Now it shows up properly for me both places
Dunkman
@CBF1
Likely a glitch in the website.  My link from the app and website seems to work fine.
The link is right, but it is missing your referral code after the equal sign =
So if you want to make your own link: just enter your code after the equal sign.
