Missing Refer a Friend Reward
Toothpick
On approximately July 7/2021 I referred a friend and so far I have not received any Reward Program credits for it.  I can provide the cell number if required.
gpixel
@Toothpick
you will need to tell your friend to contact customer support. The agents won't help you. keep in mind if you ever refer anyone else. it should be in your account immediately
pkaraa
If the referred account is still active and you dont see it your awards then click the blurb on the bottom right and create a ticket.
t_p
In that case you should contact CS for help:
Triguy
Log into your account and check under rewards.  Their last four digits of their phone number should appear.  Is their account active ?
Here’s when and how to contact our Customer Support Agents:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work.
