10-06-2022 10:50 AM
Hi I purchased an addon of talk minutes for $5 for 500 min awhile back. My monthly limit had expired and I had 91min remaining in my addon purchase. However I could not call, I was told I had no minutes remaining. So i had to purchase another addon of talk. Do the addon minutes expire after a certain amount of time ? I was under the impression they always remained ?
10-06-2022 12:42 PM
@julian_sc And there has been issues with the website showing older cached information.. try incognito while logging into your account.. should then show the correct info
10-06-2022 10:54 AM - edited 10-06-2022 11:00 AM
The add-on minutes stay on your account and get used if you run outta regular plan minutes. Sounds like you've used 'em up. Remember...checking voicemail also uses minutes.
