Midnight data usage?
Marv44
I just looked at my usage summary, and realized that data is coming off my phone twice, both times at midnight or shortly after. I am definitely NOT on my phone at that time! Does anyone know why this Data is being used at this time? Has this also happened to anyone else? I have no idea why this is happening.
Marv44
Makes sense, thanks so much!
Marv44
Makes sense. Thanks so much!
NvBD
I noticed that on my account as well. Like around 4mb used.  I did a bit of research, take a look at this post from way back.  Data usage overnight - Community
@Marv44
PM does not update the data usage constantly.  In fact, it only update it twice a day.
So, any entry you see is just a total usage between that timestamp and the timestamp of the previous entry.  The early morning usage  you see on the Usage log does not mean it was used in the morning but a total usage for the last 12 hours.
Also, for correct usage reading, always use Incognito mode to login My Account to avoid reading cached old info
