08-12-2026 07:29 PM
When I go to check my rewards total, why does it come up with my husband’s rewards total? Are our rewards linked?
08-12-2026 08:01 PM
Thx, I don’t have the PM app, but I will make sure I log out of everything. Thx for your help!
08-12-2026 08:00 PM
Ok thx for that confirmation…I will try it!
08-12-2026 08:00 PM
Thx I will try it!
08-12-2026 07:36 PM
please login again using browser with Incognito mode, or try with a different browser
08-12-2026 07:35 PM
No two accounts are linked. You must always log out of each accounts and clear cache then login with the other credentials.
08-12-2026 07:34 PM
hi @Lori44
it is a browser cache or app cache problem, common issue with PM stie/app. Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
