05-26-2023 11:11 AM - last edited on 05-26-2023 11:36 AM by computergeek541
Why am I seeing consistent data usage overnight when I’m not using the phone and am at home with my wifi
05-26-2023 11:39 AM
HI @Sam871 PM usually only show 2 lines of data per day. So, the data you see at midnight is the total data used in the last couple hours, not a live record of data used
05-26-2023 11:38 AM - edited 05-26-2023 11:38 AM
The Self Serve accout doesn't indicafe af what time data was used. It's a summary of half of a day's usage.
05-26-2023 11:35 AM
Could be a few options.
Hope any of this helps, but some may be obvious
Weak Wi-Fi signal: If your Wi-Fi signal is weak or intermittent, your phone may switch to mobile data to maintain a stable internet connection. This can happen if you're far away from your Wi-Fi router or if there are obstacles blocking the signal.
Wi-Fi disconnects during sleep mode: Some smartphones have a feature that automatically disconnects from Wi-Fi when the device is in sleep mode to conserve battery. If this setting is enabled on your phone, it will switch to mobile data when the screen is off, even if you're connected to Wi-Fi.
Background app activity: Certain apps on your phone may continue to use data in the background, even when you're not actively using them. These could be apps that sync data, check for updates, or download content while running in the background.
Wi-Fi assist feature: Some phones have a feature called "Wi-Fi Assist" that automatically switches to mobile data when the Wi-Fi connection is weak or unstable. This is intended to provide a smoother internet experience, but it can result in data usage when you expect to be using Wi-Fi.
To troubleshoot this issue, you can try the following steps:
05-26-2023 11:35 AM
Check under Cellular data on your phone for a list of apps using data.
