Mexico?
JThornton
Can you please tell me if I can get an add-on for Mexico and if so how much and what does it cover?
hairbag1
@JThornton
how long do you plan on being in Mx ? If going for a few weeks or months, consider getting a local sim and a cheap plan. I've used Telcel and can call most any Cdn, US or Mx number while I'm in Mx, Us or Canada. I have 3GB data and unlimited texting / calling for 30 days for less than $20 Cdn. Your friends at home would need to call long distance to contact you...but they could text you to call them back right away.
Alternative is get a free voip app such as TextNow to make free calls home using wifi or separately purchased data.
DDM69
Download Airalo Esim.  This works great for world travel and is well priced.
mojorising
@JThornton get a sim from Amazon. They have a lot of options from physical sims and e-sims. I got one for my trip to Portugal this past September and worked without any problems.
Meow
PM provides service add-on for USA only.
JRod
@JThornton
Unfortunately this is not an option.
Public Mobile only offers service in Canada and the US (with a Canada-US plan or roaming add-on). You will have to look to a local pre-paid sim, travel eSIM, or look to other carriers that now offer Can-Us-Mexico plans.
will13am
@JThornton , there is no Mexico roaming add-on option with this service.  The only roaming available is US.
