02-13-2024 09:16 PM
Has anyone had issues with messaging? I have an android and have done everything possible on their end to resolve and they think it may be a carrier issue at this point.
Never had this issue before. Cannot message attachments (photos or documents) and cannot reply to group text threads.
If you've had this issue and resolved, plase share.
Thank you
02-17-2024 05:46 PM
Can also confirm this works.
I use a Sony Xperia 10 III.
I haven't been able to send MMS since the 14th, and I coincidentally upgraded to a new plan at the same time, so I though that was the issue.
Turns out it was just the announced MMS changes affecting APNs.
Tried manually entering everything (I'm used to it because I remember years ago I had to modify my APN to get data to work when I switched to PM as my carrier).
Gave up and followed the advice - deleted all custom APNs, reset to default APN, edit "MMSC proxy" and
"MMS port" to the mentioned values, and restarted.
Pictures that had failed to send for days suddenly showed up.
*I also double checked that wifi was disabled the entire time to verify MMS was working again - also disabled automatic wifi turning on.
02-14-2024 02:36 PM
Thanks for sharing. Unfortunately this is not resolving the issue for me. I've tried a couple of times. Appreciate your help
02-14-2024 01:22 PM - edited 02-14-2024 01:22 PM
i suggested a similar fix earlier from someone's post. And today, we have another member confirmed that it works:
"deleted all the APN settings reset the values added in the PM recommended settings"
02-13-2024 11:43 PM
I can qsk OnePlus about downgrading.
This is the post about compatible devices from PM:
02-13-2024 11:40 PM
Great question. It was about a week ago when i updated to Android 14. Oneplus is sending me to Public Mobile for resolution
02-13-2024 11:37 PM - edited 02-13-2024 11:39 PM
@Kjh875 it could be the latest OS update that broke it. Did you got the issue right after the update?? I was reading Simone in Koodo have the same problem with OnePlus on Android 14. I am not sure if downgrade back to.l 14 is an option, but report to OnePlus support and wait for the next major update
In the mean time, use other app to send multimedia, like WhatsApp or FB Messenger or Google RCS
@T250cc1 I would hold on to the Android 14 update until we have other confirming if MMS works on Android 14 on OnePlus
02-13-2024 11:32 PM
I have the latest android 14 update. I have a feeling my phone is no longer compatible with PM. They've come out with a list of phones and mine is not on it. Looks like I'll have to find a new carrier. Good luck. I hope you fare better than me.
02-13-2024 11:28 PM
Have a Oneplus 8T with Android 13, still able to mms with no change to my APN settings. I'm curious if I will have the same issues as you when I received Android 14 update later
02-13-2024 10:40 PM
Oh no! This all started over the weekend. Thanks for your reply.
02-13-2024 10:13 PM
@Kjh875 wrote:I cannot reach antone at Public Mkbile as everytime, i trh to create a ticket, I get an wrrie.
02-13-2024 10:12 PM - edited 02-13-2024 10:13 PM
try this
Key is " I deleted the new custom access point and then, hit the thee dot drop down menu, and it gave me the option "delete all custom access points" so I hit it. It then spit out a new set of default Public mobile APNs"
But I think you still need to update these after..
MMSC proxy: mmscproxy.mobility.ca
MMS port: 8799
02-13-2024 10:08 PM - edited 02-13-2024 10:16 PM
02-13-2024 10:07 PM
Yes, that is my apn setting
02-13-2024 10:04 PM
it is almost 100% certain PM has some issue with supporting MMS with OnePlus after the recent change.
Please also post a question at Onelus Community https://community.oneplus.com/ as well as open ticket with OnePlus if possible
02-13-2024 10:03 PM
Thanks for your reply. I've double checked these settings.
I believe this is an issue with PM not supporting certain devices after Feb 14.
02-13-2024 09:57 PM - edited 02-13-2024 10:01 PM
can you double check you have these APN settings?
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
02-13-2024 09:51 PM
I have a OnePlus Nord 30 just bought in Sept.
I appreciate your reply and sharing this with me.
I'm about to lose it. How are they allowed to do this? I suspect my phone ((despite being new) is no longer compatible. Wow!
02-13-2024 09:47 PM - edited 02-13-2024 11:42 PM
I have a new OnePlus Nord 30 phone with Android 14.
What is going on with messaging and what is the resolution? Purchasing a new phone is not an option.
02-13-2024 09:40 PM
Thanks so much for your reply. I've double checked APN settings and it's all correct
02-13-2024 09:31 PM
Which model of Android phone? Does data work? Looks like you are having MMS text issues.
Here is an announcement:
You might need to update your operating system and update APN settings.
02-13-2024 09:31 PM - edited 02-13-2024 09:32 PM
@Kjh875 Seems like MMS issue. Please check your APN network settings and make sure it matches the one found here.
https://www.publicmobile.ca/en/bc/get-help/articles/set-up-data-on-an-android-phone
https://productioncommunity.publicmobile.ca/t5/Announcements/Picture-and-Group-Messaging-End-Date-Fe...
