Message send failure in a group message
Liuhelen
When sending a group message using iPhone 11, does the message send failure happen only to the invalid numbers or everyone in the group?
Happy new year and thanks,
Helen
@Liuhelen  - I am reading your question, and wonder, how can an invalid number receive an message?
OR, are you asking if the valid people in the group are getting a message saying about the invalid numbers in the same group.
So, I would answer this. It would depend on how the recipient's group messaging is set up. Whether they have it set up to receive as individual texts (they would not receive the invalid numbers included), or as a group (then, they likely would receive the list of numbers included).
I don't think the 2nd attempt is answering the question either..
@Liuhelen
on an iPhone, go to Settings > Messages and turn on MMS Messaging. If you don't see an option to turn on MMS Messaging or Group Messaging on your iPhone,
try to check update your device,
darlicious
@Anonymous
None of what you posted answers the OP's question.
@Liuhelen
Good question. I use Android so I have no idea. But someone will reply soon that does.
@Liuhelen
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
and you can try to reset network settings and Changing APN Settings,
for iphone
Go to Settings > General > Reset > Reset Network Settings.
This also resets Wi-Fi networks and passwords,
or visit  Here link,
APN Settings On An IPhone click Here link,
Ensure you have the correct APN settings by visit Here link,
and try manually selecting network "3G ONLY"
for iPhone visit Here link
or Here link
for iphone  go to Settings > Messages > To turn iMessage on or off,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet Wi-Fi is on is not going through the Picture or a video messaging,
you have to do this to going through you will need to turn your data on to send a Picture or a video messaging in world-wide,
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
