Message failed to send but still delivered
briannguyen92
Hi, why do everytime I send my text, it tells me that message has failed to send but it is still delivered to the recipient? I have been struggling with this for a while now since I have been sending many duplicates messages to my friends and family. Thank you so much in advance!
pkaraa
Turn your phone off, remove the SIM card,
wait for a 2 minute and put it back and turn on.
Else try the SIM in a different phone to narrow down the faulty SIM or phone.
@briannguyen92 wrote:
I have tried it and it works perfectly! Thank you very much!
@briannguyen92
glad it works...
enjoy your service....
briannguyen92
@briannguyen92   what kind of phone is yours?  I think it's a common issue with Samsung S7
@briannguyen92
Along with @Anonymous @recommendation, check your setting if you have an iPhone.
Go to Settings>Messages>check if Send as SMS and MMS messaging are enabled.
@briannguyen92
do one thing Make sure your phone is off before removing your SIM card,
and take your SIM card out and waiting for a 2 minute and put it back and turn on -This one is quick and simple.
what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
or can you do try reseat the SIM card
1. power off your device
2. take out the SIM card,
3. wipe it clean SIM card,
4. put it back and power on,
5. toggling airplane mode off/on,
and do again Rebooting your phone means to turn off your phone and turn it back on again.
and if you have android device clear cache at app,
