New subscriber
Ish01
Received a message from Rogers for transferring a number but my answer of YES is not being delivered. Need immediate help
11 REPLIES 11
if you reboot the phone with the Rogers sim and the Rogers account still work?  I would call that porting team again and ask.  Just ignore the message about cannot find the number and enter the number a second time and it will connect to a live agent
Ish01
Yes  my Rogers account is active
Ish01
Yes I am porting to PM but port is not completed as I could never send a response back to Rogers. The message shows up as undelivered.
hi @Ish01
Just to confirm, you are porting into PM, right?  If it is, I think that port was already completed . Please ask support agent to confirm by direct message :
Ish01
After installing/activating PM esim, I do not see Rogers Sim
that prompt means poet is completed, so it is a problem with the sim.  Ask PM to check by message them
@Ish01
Is your Rogers account still active. It needs to be active to receive the SMS text and reply with YES.
You will need to talk to Rogers about your account so you can port out.
Ish01
I am trying to call that number but automated system asks my number but the number I am trying to port does not exist.
Ish01
My Rogers SIM is not working as I am not being able to send a response back for porting authorization
@Ish01
Your Rogers SIM will continue to work for about 2 hours until porting is completed. Once porting is done. Your phone will show SOS. At this point, power off your phone and switch to the PM SIM.
hi @Ish01 you are porting from Rogers to PM? You still have the Rogers sim and is it set as enabled?  Check and re-enable it
if you need PM porting team to check, call them and ask
I have sent you the number to PM Porting support team Please check your community inbox: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
