08-02-2026 06:06 PM
I need a manual bypass to port my number back to Virgin as soon as possible.
08-02-2026 06:45 PM
Ticket has been logged.
08-02-2026 06:40 PM
The provider has submitted the request approx 40 mins ago. I am waiting for Public to release the number.
08-02-2026 06:38 PM
I have tried all of these things. I do not want Public fixed. I just need it manually done.
08-02-2026 06:37 PM
make sure you have PM sim still enabled and set as Primary (you might need to disable the new esim for now)
ask your new provider to submit the porting request again.
but if you really need help, don't hesitate.
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
08-02-2026 06:35 PM - edited 08-02-2026 06:37 PM
@Frank39 wrote:it is active and in good standing. The problem is something is messed up with the esim and I have no access to the network. I cannot receive or send texts or calls. I cannot receive the text from Public so that I can go back to Virgin, so I need them to manually bypass. I am travelling tomorrow and I need this completed ASAP.
First, there are simple fixes you can do to resolve this.
1. Do a network reset on your phone. Depending on what phone you are currently using, you can go into your settings and reset your network and reboot. This happens when two different services have their network information in the same "folder" sort of speak. Doing a network reset will clear that up.
2. You can go into airplane mode for 10 minutes, turn off phone for 5 minutes and then restart phone. Turn off airplane mode and this will reconnect you to the network.
3. If you are travelling, just know that Public Mobile only works in Canada, the US and Mexico. It doesn't work in any other country.
4. To confirm if the port from Virgin worked, insert your Virgin SIM card and see if it's active. If it is, the port didn't go through and you can contact Virgin to send back your number. If it was an eSIM, place the Virgin eSIM as primary and see if you have service. Same info as above.
If you're still having issues connecting with Public Mobile, you can reach a customer service agent this way to troubleshoot further.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
Public Mobile Chatbot - Contact Us
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
08-02-2026 06:29 PM
08-02-2026 06:16 PM
hi @Frank39 sorry , no manual bypass
why you need that? your account not active? only number from active account can be ported out
08-02-2026 06:16 PM - edited 08-02-2026 06:26 PM
you must keep your Public Mobile account active and in good standing...then you should have no trouble transferring to Virgin.
sp
