Manual Release of SIM
Brian7777
New in Town / Nouveau en Ville
How do I get my Sim manually released, I’ve been unable to speak with an agent.
Are you asking about how to remove your SIM card from the device? Current devices usually have a SIM card tray that can be released using a PIN.  Power down your device before using a PIN to eject the tray and the SIM card.
hi @Brian7777
what exactly you want to do ?
but to work with agent, please   submit a ticket with CS agent:
Dunkman
@Brian7777
What happened?  Are you looking for the PUK code?
If you are unable to submit a ticket for CSA help,
Send a private message to CSA through the following link :
