Making and receiving calls
enidcundari
Hi there,
I am unable to make or receive calls on my phone. I have autopay setup and March 6th was my renewal date. The message I am hearing when trying to make or receive a call, it says my account does not have an active plan. I can text, the account is fully paid.
Please help this is ridiculous as I rely on the phone for my kids
I've submitted two tickets
13 REPLIES 13
enidcundari
Here's the answer:
"After checking, we saw that your rateplan had not been renewed. We did some troubleshooting on the account and, as your $41.25 4GB rateplan was no longer available, I took the liberty to change to the existing $40 15GB rateplan. The rateplans are identical (unlimited calling and texting), the only difference being that this plan is $1.25 cheaper and comes with 11GB extra."
 Nice if they actually reached prior to shutting it off when they change the plans
Mikester80
It's almost like they are not processing the payment? Mine was due March 6 as well and I'm on autopay. Same issue
@RongAn wrote:
I am having the exact same problem. Please post when you get it resolved.
@RongAn   Please come back and check the Community here
but it is better to open ticket with PM support so they are aware you are one of the affected
Please open ticket with PM support using Chatbot:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
RongAn
Sblandin
Same issue as original poster.
talexanderarab
I am also having this issue. I am NOT happy about it. I am needing to get a call from a surgeon to update me on a family members surgery.
@Mikester80   Pretty sure PM is aware of the situation, but please still open a ticket with Pm support so they can help:
Mikester80
I have same issue
@esjliv wrote:
@enidcundari
Can you try your SIM into another phone? If calls still don't work Turn off VoLTE if you have a VoLTE enabled phone. If that does not work, go back to your SENT messages and ask for an update on your ticket.
Perhaps you are affected by this: https://productioncommunity.publicmobile.ca/t5/Announcements/Resolved-Service-Impacts/td-p/955119
Although they mentioned VoLTE in the announcement, I am somewhat skeptical.  I have a pixel phone that is VoLTE compatible.  However, I do not have a setting to turn the feature on and off.  In any event, my problem went away on its own before my ticket was looked into.
will13am
@enidcundari , the loss of calling is an issue that have affected a number of customers in recent days.  The problem seems to be exacerbated by a renewal.  I had the problem and a friend just informed me of the problem today.  Just wait patiently for the ticket to be looked into.
@Ahrtn wrote:
I am in the exact situation. Trying to figure this out ASAP as I need to use my phone for work…
@Ahrtn - submit a ticket to CSA.
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
Ahrtn
@enidcundari
