MMS
10-15-2018 02:22 AM - edited 01-05-2022 02:09 AM
Do the Public Mobile plans allow MMS, particularly, the $10/30days for 50 min and 50 outoing texts that I am using?
If yes, would outgoing MMS messages be counted towards the 50 outgoing texts quota, and how can I send them (i.e. how does my cell phone need to be set up or configured)?
Thanks in advance!
Joining Public
10-21-2018 10:44 PM
@wleung wrote:Thanks for your replies.
The Moderator Team has just confirmed with me that "Yes, MMS is definitely included in your plan and it will count towards to 50 outgoing texts."
I will test it out to see how it works when I have the chance.
You need to enable data on your phone in order to send and receive MMS. The $10 plan does not include data. Since PM plans are prepaid plan, you will not charge for data usage used by MMS.
10-21-2018 10:31 PM - edited 10-21-2018 10:35 PM
Glad you got an answer. MMS is just an sms that includes some data in the form of a image. With that being said you will need data turned on to use MMS even though you do not have data as an option.
EDIT: Set up your APN settings as if you had data.
10-21-2018 10:20 PM
10-15-2018 02:54 AM
@wleung a écrit :Do the Public Mobile plans allow MMS, particularly, the $10/30days for 50 min and 50 outoing texts that I am using?
Thanks in advance
The following is the complete APN configuration I use in Android:
Name: Public Mobile mms only
APN: sp.mb.com
Proxy: Not set - leave blank
Port: Not set - leave blank
Username: Not set - leave blank
Password: Not set - leave blank
Server: Not set - leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Authentication type: Not set
APN type: mms
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
* the original values for APN type: default,mms,agps,supl,fota,hipri
By using this configuration, your cellular data connection will only work for MMS. If you have or add a data plan and wish to use cellular data, you must restore 'APN type' to the original values (listed above).
10-15-2018 02:27 AM - edited 10-15-2018 02:51 AM
I doubt it, it only says unlimited incomming text so it wont include mms. And for outgoing I don't think it would work to send images with sms app. Thats what the plan says.
Edit : Thats weird this user says that he can send mms and it is not counted in those 50 limit.
Edit2: I guess sending mms is unlimited but it says nothing about receving them.
So you can send 50 sms and unlimited mms(pheraps try the edit2 link to convert sms to mms) and recevie unlimited sms but recevie mms I have no ideea.
