MMS suddenly not working
kateyyj
Have not changed anything, MMS suddenly stops sending/receiving from one of my 2 accounts. tried reboot, tried off WIFI, data turned on, It just happened suddenly.
the calling working fine. any help? thank you.(it is Huawei Mate SE. other huawei works as normal)
also data usage went up if nothing turned on, it is new as well.
35 REPLIES 35
@kateyyj wrote:
hi, i am so happy we switched app to messaging.... it works, but a little bit slow, thanks everyone. bravo
If you'd be so kind:
a) What app were you using that failed?
b) Which are you using that works?
kateyyj
geopublic you solved it
kateyyj
kateyyj
yes, data works, sms works, only MMS canot be sent or downloaded
Luddite
@kateyyj It's a long thread so I may have missed if you have checked that it's only MMS that will not function? Can you still access the internet with other apps with wifi turned off?
kateyyj
we are using messages, sms works,  should we re install it? what else we should try?
@kateyyj  What application are you using to send the MMS? Can you try using another app to see if it works? If yes, then the problem is with the app that you are using.
@kateyyj please try sending a mms message usung the working SIM in the phone giving the problem. Thanks. If you have a stuck mms message, delete it and retry sending it from scratch. Thanks.
kateyyj
i have done this, works on one phone, so I think the problem is the phone, not PM, but nothing changed lately.
@kateyyj Can you swop the Sims and try sending an mms message on both phones, so that we can determine if its a PM or phone problem. Thanks.
kateyyj
so I dont know what to do with the APN, no update lately.
kateyyj
unfortunately didnot work.
@kateyyj wrote:
what is the force stop for?
yes data turned on, i have checked the APN with another phone and also the PM website
@kateyyj  The force stop is suggested because there might be an issue with the messaging app and by doing that it will re-initialize it. Don't worry it will not harm anything. In fact, I have done it in the past and has always cleared up similar issues.
It's to close the program fully to remove any memory remnants.
Edit: it seems unlikely to me that the APN is the problem. It had been working. Unless someone (you) inadvertently changed something there or an OS update or an app update, I don't think you need to muck around in there.
kateyyj
@kateyyj wrote:
I have tried another phone, works well, so it is the phone, double checked and compared APN,,so what to do?still canot get MMS
You may want to try some items from this site (different Huawei model though)
https://thedroidguy.com/how-to-fix-your-huawei-mate-10-pro-that-wont-send-mms-messages-troubleshooti...
kateyyj
neither working, send and receive,works on another phone
Your first message said send and receive. This one says receive. Which is it?
@kateyyj  Did you try to force close the messaging app on the problem phone? Is data turned on? Post a screenshot of the APN settings from the problem phone.
kateyyj
 @kateyyj
Don't worry about data when it comes to MMS. You could even have a plan with no data and you could have MMS.
Naepalm
MMS only works on Data it will not work with Wifii.
You have to have your data turned on, if you have no data then this will not work to send.
popping
@kateyyj
If you used all your data for your current cycle, options to get more data:
1. If your current data limit does not meet your 30 days' need, you may change a plan with more data. You can do the plan from self-serve. You get your data back immediately with plan change.
2. If you want to renew the same plan early, you need to create a moderator support ticket using the ? button at the bottom right hand corner of this page. Moderator wait time is up to 2 days or more. If your next renewal date is up to 2 days away, you may just on data diet for a few days until after renewal.
3. You can buy data add-ons $15 1GB data or $10 200MB data. Expensive option
gblackma
@kateyyj  try a network reset, restart and reenter you WiFi passwords and APN settings if necessary, enable data and try sending an mms text message. If this doesn't work let us know.
popping
Login to your account.  What is your data usage line saying?
If you don't see your data usage line, you used all your data for the current cycle.
My data usage line showing that I used 45.396 out of  250 MB.
  • Data & Add-OnsAmount Used
    $0 Free Holiday Giveaway: 1GB Add-on
    140.206  /  1024 MB
    $0 Free Holiday Giveaway: 400min INTL Long Distance (incl CA & US)
    1  /  400 MIN
    1GB Promo
    102.004  /  1024 MB
    250 MB at 3G speed
    45.396  /  250 MB
    500 min Canada-Wide Long Distance
    189  /  500 MIN
 @kateyyj
Has anything changed though?
Two things to try:
1. Try the lost/stolen feature.
Log in to self-serve. Plan & Add-Ons from top menu. Lost/Stolen Phone from next menu. Suspend Service button. Log out. Wait a few minutes. Log back in and back to Lost/Stolen Phone and Resume Service this time. Log out. Restart phone.
2. Manually add $1 into your account and restart the phone.
@kateyyj wrote:
so I should double check VPN?
I would do what @geopublic suggests and try your sim card in the other phone and see what happens.
kateyyj
@kateyyj   I know a few times over the years that updates have changed certain things when it was not intended
@kateyyj wrote:
question, why do i need to set APN all the sudden? I never set my APN on both accounts, one still working, one stopped lately.thanks
@kateyyj  Good question. If you did not make any changes to your APN then more than likely it's not an APN issue. Just make sure the APN Type field contains mms or compare it to your other phone that works.
Best to try the sim with the issue on the other phone so see if the mms goes out. If it does then the problem is the phone and not Public's network or your account.
