07-28-2024
06:06 AM
07-28-2024
11:08 AM
Dunkman
Hey, I have tried all the standard troubleshooting regarding MMS messaging but I am experiencing MMS issues related to iPhones with my brand new OnePlus12R running Google Messages (have tried various messaging app, all the same).
Very specifically, I have full MMS/RCS functionality with other Android phones but I can neither send/receive, nor view/create a group chat containing iPhone users. This issue extends to MMS messaging (pictures, gifs, etc.) as I cannot use MMS with iPhone users (groups nor individuals), only SMS.
MMS and RCS are functioning perfectly with Android groups and individuals. SMS functions with iPhones.
In my family group chat I have 3 androids and 2 iPhones - this means I currently cannot view or receive messages from this chat (even from the android users). Attempting to recreate a group containing the two iPhones will cause all of my messages to fail to send. I can create a group chat with only Android users and I have full functionality.
MMS functions, SMS and Mobile Data are fully functional otherwise but all MMS with iPhones are non-functional.
I have reset the phone, cleared cache, reset/edited/added new APN, reset mobile network settings, toggled RCS on/off, toggled MMS/SMS group settings, uninstalled/reinstalled Google Messages app, recreated groups, tried APN edits including capitalizing, etc. The same settings, sim card, apps, etc. will allow full functionality on my previous phone the LG G7 Velvet.
Any idea what may be causing this hiccup with iPhones?
07-28-2024 10:51 AM
Hey, unfortunately my family's iPhones have maxed out at iOS17, I don't have the ability to send/receive RCS from iPhones on my end.
07-28-2024 10:31 AM
hey, iPhone just allows RCS with Android, if those iPhones are your family's, maybe update them to latest iOS and enable RCS. You can turn it on "RCS Messaging" on the network screen.
but if the MMS/SMS problem from other iPhone not from your family, then maybe the person not properl enable sms on their iPhone?
07-28-2024 09:00 AM
It’s strange, if you have another line from other providers, give it a try.
it could be an issue between iOS and onepleus12, it could an issue with public mobile
07-28-2024 08:08 AM
Unfortunately no, no change. It's so strange it seems so specific I can't imagine it's a hardware issue.
07-28-2024 08:07 AM
Yes, the iPhones are on iOS 17, well above iPhone 8.
The iPhones have no problem sending/receiving MMS from other phones - it is just my Android. Other Androids are able to send/receive MMS.
07-28-2024 07:13 AM
For MMS to work on iPhone, you need to have at least iPhone 8 or higher and enable data to be able to use MMS group chat and picture.
If you have iOS 18 beta 4 there is a chance that RCS may work on your phone.
07-28-2024 06:53 AM
if the iPhone users turn off iMessage, & ensure MMS is enabled, does that make a difference?
