06-01-2024
03:51 PM
06-01-2024
11:57 PM
computergeek541
I recently moved to Public Mobile and all is good except that I can't send MMS messages. (That is, I can't send photos or group texts.) I'm on Android btw.
I've tried various APN settings (rebooting between each change)
Nothing works. (I may try using the textra messaging app in Legacy mode as suggested here, but other sites suggest that app may have privacy issues.) It seems Telus changed their MMS server settings a few months ago and broke things for a lot of people. This is really annoying since my phone works fine with other carriers here and in Europe. Looking at Telus' announcement though, I see my phone explicitly listed as being affected.
Is there any hope other than upgrading my phone (ridiculous imho), or dumping PM (and anything on Telus I guess)?
01-07-2025 08:07 PM
Just to update this in January 2025
I just ported in to PM and could not send mms, I followed the final solution but it still wasn't working. Using the final solution AND putting the APN in all caps [SP.MB.COM] did the trick for me. Problem solved. FWIW.
07-12-2024 07:07 AM
tried your settings but unfortunately it wasnt able to fix my MMS problem on my phone. it had been working a few months ago..then MMS stopped working...tried using textr and other messaging apps...no joy
back on google messaging app
beyond frustrating
06-01-2024 10:12 PM
HI @Ocram
the sim card shouldn't matter, the same old one should be the same as before (expect the "memory" inside is bettter, but it is almost irrelevant now as no one really save sms text or contacts on sim card anymore"
06-01-2024 10:07 PM
Thanks. I had tried variants of those things with no success. I think the way I was testing things might have led me astray. (See my response to softech.)
06-01-2024 10:04 PM
Well, I'd swear I tried those settings already but they worked this time. I think my testing was flawed before. I was trying "resend" on a failed attempt to send an image. When I tried with a fresh image this time, things worked! (The "resend" still fails so it must be tied to the old settings somehow.)
Ftr, I ended up going with the longer "APN Type" setting. I've settled on the "MVNO value" of "4D" as above but found that "4D4F", as I've seen elsewhere, also worked.
Thanks very much. I was very close to giving up.
P.S. I wonder if this happened because I used an old PM SIM card we had lying around. I wonder if a modern one would result in things working from the get-go.
06-01-2024 05:04 PM - edited 06-01-2024 05:05 PM
Hey @Ocram
This worked for my buddy but on iPhone. Give it a try and see if you get the same results.
Go into your network settings, turn off automatic and pick Public Mobile. Then reboot. After you reboot, try sending or asking to receive one.
The other thing is your auto download of MMS settings may be incorrect. Go into the Message App by clicking on the 3 dots top right corner, then to settings, then advanced and auto download MMS. if the option is set to On, try turning it off then rebooting. Then go back in and turn it back on.
06-01-2024 03:53 PM
@Ocram what phone do you have??
please check this APN settings again. For some phones like OnePlus, you need to make a new APN profile, save and select the new one instead of updating existing one :
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
