MMS issue
02-29-2024
10:32 AM
03-01-2024
03:15 AM
computergeek541
Can't get pictures to send or download all of a sudden on Google messages. I'm using Android 13. It was working a few days ago. Any help would be great.
Phones
03-02-2024 09:56 PM
When I search for threads about MVNO settings I can seem them listed now, but none of the official support articles or threads about Xiaomi phones mentioned this. This thread is simply my attempt to make the fix for phones of those sister brands more searchable. One cant go through every MMS broken thread on here, there's too many!
03-02-2024 04:12 PM
thanks @Quincy1 yes , this is the same setting s as people posting on the community
03-01-2024 12:48 PM
I am experiencing the exact same issue. Called my phone company, they said that their last update only allows users to send/receive MMS under 1MB. I have tried sending items less than 1MB; that only works with others who use Google Messages. But i cant receive pictures from other google messages users. I have tried everything mentioned here and still cant get it to work. Im literally at a loss at this point. What else can I do?
02-29-2024 01:01 PM
That's what I did with my King Kong 9 and it did nothing
02-29-2024 01:00 PM
I'm in Canada and using a Cubot King Kong 9 that was bought from AliExpress. Everything else works except MMS
02-29-2024 11:23 AM
HI @Mohawk44
what phone do you have? can you delete the current APN settings and re-add a new one for PM? Some needs to do that before MMS works again
02-29-2024 11:22 AM
It's possible.
Instead of changing the information, see if there is a way to delete them all and re- add. Hopefully will work.
02-29-2024 11:17 AM
@Mohawk44 wrote:I did that and it's not working.
Could it be because my phone is from outside of Canada?
Are you right now in Canada or 'outside'?
Or your phone is not for Canadian market?
If MMS worked before did you change anything on your phone recently? DATA has to be on for native MMS to work. Do not use 3rd party app for SMS/MMS.
02-29-2024 10:49 AM
02-29-2024 10:37 AM - edited 02-29-2024 10:37 AM
Try go into settings click connections click mobile networks and click access point names. Press three dots and click reset to default. Then restart your phone.
If that doesn’t work go back into APN settings and use the information from this post.
Add this:
- APN: sp.mb.com
- MMSC proxy: mmscproxy.mobility.ca
- MMSC: http://aliasredirect.net/proxy/mb/mmsc
- MMS port: 8799
- MCC: 302
- MNC: 220
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
