a month ago
- last edited
a month ago
Dunkman
I just receive a text message :
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant
a month ago
It is better to provide PM your old provider's account number as the porting info instead of IMEI.
There is a number to call to talk to live support, you can give them the old provider's account number and porting team can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
**Monitor your Community inbox (envelope icon on top right) after the ticket is opened. CS Agent will reply to you there
