05-23-2026 02:48 PM
Hello,
I received a text message about transferring my number, and I replied “YES.” Then I received another message saying that my MEID was entered incorrectly, so the transfer from Fizz could not be completed.
What should I do to fix this issue?
Thank you.
05-23-2026 02:53 PM
@Olena1912 You will need to contact PM CS Agent by opening a ticket from bottom right chat box or private message. They will need to reinitiate the port in request. Always use account number instead of IMEI when porting in.
If you need to contact PM Customer Support Agent, Start a Chat to Create a Ticket OR visit the Get Help page.
05-23-2026 02:52 PM
yes, it is safer to use old provider's account number than IMEI when it comes to porting
There is a number to call to talk to live support, you can provide them the old provider's account number and they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
**After opening the ticket, please monitor your community inbox (envelope icon on the top right), the customer support agent will get back to you in sending a message there.
