01-28-2024 06:52 PM - last edited on 01-28-2024 06:54 PM by computergeek541
I never had issue receiving verification codes for any institutions before, but my number seems to be blocking MBNA verification code for both text or call options.
I called MBNA and after numerous tries, they told me I have to contact the service provider (Public Mobile) to get it unblocked or something. Has anyone encountered this issue before? I cannot access MBNA account due to this.
01-28-2024 07:01 PM - edited 01-28-2024 07:01 PM
Then I'd recommend reaching out to a CS Agent to resolve this.
Keep an eye on the top right corner for their reply.
01-28-2024 06:57 PM
I had Public Mobile number for 4 years now..
01-28-2024 06:55 PM
@jlsun2 wrote:I never had issue receiving verification codes for any institutions before, but my number seems to be blocking MBNA verification code for both text or call options.
Did you tranfser a phone number from another carrier? In those cases, these types of text messages can take a a little while before they start being received. In the meanwhile, you will need to work with MBNA to use an alternative 2FA method.
01-28-2024 06:55 PM
Hello @jlsun2
If you're new to Public Mobile, it will take a bit for the system to work.
