Loyalty Program
bella62
Why I am not getting any more loyalty points after two years?
I am with PM for more than FIVE years?
Bhairavi
JL9
Sounds like you may have switched to the new rewards program, if you give some further details we can clear it up for you.
Alexandf
@bella62
Login Page rewards
it's showing there or not, if not see it, open ticket with PM support and ask them to check it
 At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS_Agent
Meow
If you are 5 years with PM you should get $5 reward.
Look at your payment history and let us know what it say there.
Hi @bella62 did you login to My Rewards site? do you see things showing in dollar or point?
if it shows, how much loyalty rewards it shows?$2 or $5?
dust2dust
What do you mean "after 2 years"? Are you still on dollar rewards or did you switch to the new points system?
DDM69
Loyalty caps at 5 years/points
