09-24-2022 09:18 AM
Hi,
I was overcharged for around $5 per month for three consecutive months. The amount due shows $20, but my card was charged for $25 every time.
Who should I reach out to? There seems is no support team.
Thanks
09-24-2022 04:39 PM
@hTideGnow- And when many of us know that support all too often replies with misinformation that doesn't help the customer.
We can narrow down the problem to suggest to the customer what to ask, if needed. Rather than sending the customer off with an unknowing "I was overcharged".
09-24-2022 04:33 PM
Hi @Alexandf don't you agree we should ask for more details before sending everyone to CS agent?
09-24-2022 03:19 PM
open ticket with PM support and ask them to check it
At https://publicmobile.ca/chatbot.
Start by typing "Submit a ticket", then click "Contact Us", Then click "Other", then click "Click here to submit a ticket
have trouble with Chatbot: Private message CS_Agent
09-24-2022 12:16 PM
Yes more history please. You say you were paying $23 in recent months. That's $5 more than what you're showing here. Is that your My Upcoming Bill details?
When did you start this plan? I think you can do better with current plans. It's now twice the data for a $35 plan. But you're sitting at $30 so maybe that's fine with you. That's $5 more than the 1gb plan.
09-24-2022 11:51 AM
Hi, thanks for your reply.
09-24-2022 11:48 AM
Hi @wotter123456 can you post the payment history from the previous month as well? would like to know what is the difference
What I suspect is that you had a $5 credit from the bonus friend referral? those are for couple months only.
09-24-2022 11:45 AM
09-24-2022 11:43 AM - edited 09-24-2022 11:46 AM
1
09-24-2022 10:16 AM
There is no $25 charge from PM. It has to be with some cents.
There is no $20 plan at PM. You might have some reward lowering $25 plan to $20 but you have to add tax.
What your PM account shows as charge is not the same as what your credit card will show.
