Low call volume
Willow23
Hello,
I recently changed from android to apple and the in call volume is extremely low. I contacted Apple and they didn’t know how to fix it.  The volume is on high but still no go.  I am using the 3G setting but the LTE setting doesn’t work either.
Any Apple experts out there?
@Willow23
I am surprised that Apple didn’t test to see if it is the microphone issue.
On older iPhones, the micro screen on the earpiece sometimes gets plugged up. If you have a magnifying glass to check the micro small holes. Just use a old brush to clean out but DON’T use any solvent as it could damage the microphone.
LitlLdy
@Willow23 wrote:
Hello,
@Willow23 , you said the volume is on high, did you turn it on high during a call or before making the call? That may be a dumb question so if you already know, I’m really sorry.
You have to do it while you're on a call. So, the next time someone calls you, use the Volume Up button on your phone to see if you can turn the volume back to a level comfortable to hear.
Adjusting the volume on iPhone
How to fix it when iPhone in call volume is low
Also, is your software updated to 16.5 (latest update)
XxdanxX
Have you tried readjusting the sim card I've had this issue with a sim card not properly being seated.
@Willow23  You sure it is not a device problem?
What happen if you use a bluetooth headphone?
did you try another active sim card from another carrier? this confirm if it is related to PM or not.  Similarly test your sim card back on another phone
You can try to Reset all networks and see if it helps if you think it is carrier related
For device setting, check if Phone Noise Cancellation is on:
Start with opening 'Settings' and go to the 'Accessibility' option.
Get to the option of 'Phone Noise Cancellation'. Turn it off now by sliding the toggle switch.
NDesai
@Willow23 Which iPhone do you have? How's the volume on speaker? How about when you play music or video? Have you tried taking it to an Apple store to see if they can do anything to fix it?
