Lost sim card during travel
jeandao
I swapped my Public Mobile sim card with another one when traveling in Vietnam. I forgot to swap them back when coming back to Canada. Is there any chance I can get a new sim card while keeping the current number?
Thank you.
Jean
jeandao
I was able to purchase an eSim and activate it with the current phone number. That's the quickest solution and only costs $5 + tax.
Burlrob
If you didn’t want to find/wait for a new physical sim you could sign on the app and purchase an eSIM ($5) and be back on line in a couple minutes.
colleeno
You can purchase a SIM card from Amazon for $4.99 (https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/dp/B06X9ZGDWG/). After receiving it, you will change SIM card number using either the PM app or logging into your account via the website.
jeandao
Sound great. Thank you so much for your great support.
Jean
@jeandao  Yes . Just buy a new SIM card and log in to your account profile page . And swap the SIM card number . If you can’t log into your account get support to sim swap the number for you
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send  direct  private message to support .
send  a  private message   To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
