09-06-2021 05:49 PM - edited 01-06-2022 03:19 AM
I lost my phone. If I get a new SIM, will my phone number stay the same?
09-06-2021 07:16 PM
one more piece of advise, you probably want to get your SIM from local kiosks or from Amazon if you have Prime membership. Avoid getting it from PM online as it can take as many as 3 or 4 weeks for delivery.
Hope you get things sorted out soon
09-06-2021 06:28 PM - edited 09-06-2021 06:29 PM
Bummer! And yes you can keep your phone number. And a little advice.....
Good luck! Hopefully a good Samaritan finds your phone.🤞
09-06-2021 05:55 PM - edited 09-06-2021 05:57 PM
You can log into your account to mark your phone lost.
https://www.publicmobile.ca/en/on/get-help/articles/lost-or-stolen-phone
Once you get a replacement sim then you can change it and keep your same phone number.
In order to change the SIM card associated with your account, you must now verify your request through a one-time security code that will be sent via SMS or email.To change your SIM card, please follow the below steps:
09-06-2021 05:54 PM - edited 09-06-2021 05:54 PM
Lost Or Stolen Phone visit Here link. for more information..
09-06-2021 05:50 PM - edited 09-06-2021 05:55 PM
yes is your phone number stay in your account and you need just to swap it your old SIM Card,
How To Change Your SIM Card
the SIM change functionality has been re-enabled in My Account, now with an additional security step: 2 factor authentication to further protect against SIM card fraud.In order to change the SIM card associated with your account, you must now verify your request through a one-time security code that will be sent via SMS or email.To change your SIM card, please follow the below steps:
Please note: after 5 failed attempts to verify your security code, your account will be locked, and you will need to have your account unlocked and your SIM card manually updated by an agent by submitting a ticket link,.
