10-04-2025
07:33 AM
10-05-2025
01:43 AM
computergeek541
Hi, I've had the misfortune of losing my phone. I'm wondering if there is any way to check to see if I have any voice mails using my computer. Thanks.
10-04-2025 09:29 AM
Yes @Jwbest
If you are on Windows orac , go to Microsoft store or Apple app store and download Textnow app. Register for a free phone number and you can use it to make regular calls to Canada and US for free.
You can then call yourself to get voicemail. Enter * when you hear your VM greetings and then your VM PIN
10-04-2025 09:14 AM
Computer - no.
You would have to call your mailbox from any other phone, enter number and code and get into voice mail.
