Lost phone 2 weeks ago unable to verify acct - going to old #
Sam120
Even with new phone, new sim unable to verify to change sim online.  Verification to login goes straight to lost # and then able to change to email. However once I try to add new sim verification comes up again even tho I’m using trusted device and will only go to old lost # unable to change to email verification. Onlinechats keep disconnecting or sending customer service links that revert back to login page and then regular pages.  Frustrating two days going around in circles   Updated app makes no difference
Mar25
I had a heck of a time trying to reactivate my services and install a physical Sim after my phone was stolen on October 12th. I was able to suspend services on the 13th or 14th and have since secured my account all of my accounts and updated banking information.. I spent four hours on October 22 trying to reactivate services with the new Sim. In the end, I was able to do it but you have to do it online through a browser. You can’t do it through the App. It does show my subscription is active now, but I just checked my rewards and it says my subscription is on hold and expires tonight, so I put in a ticket to confirm because this is my only communication. I hope that helps but you have to do it online not the App! It sure would be nice if this forum had live technical support. Good luck.
hi @Sam120
did you try using  Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)  ?
if same, you will need to have PM support to help.  You can submit  ticket by direct message:
