Lost my phone and found again
Mikefelton
I lost my phone so I suspended service . Now I have found it and need to re start service but it is not working
Luddite
@Mikefelton If you past your renewal date while suspended, make a payment for the full cost of your plan; then reboot your phone.
Dial 611: if you cannot connect your plan has been suspended more than 90 days and the account closed. In which case, you need to activate a new SIM/account.
@Mikefelton wrote:
I tried all 3 of those things in that order and it still won't let me text or make a call or use internet
@Mikefelton try contacting a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue, you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
Mikefelton
Triguy
  1. Log into your Self-Serve account
  2. Go to Plan and Add-Ons > Lost/Stolen Phone
  3. Select Resume Service
Hi @Mikefelton ,
After you reactive it on your My Account. You will likely need to reconnect to the Public Mobile network.
Try:
*removing your SIM and reinserting it.
*going into airplane mode for a few minutes, then turning it off.
*reboot your phone
dabr
@Mikefelton   Just log into your account and Resume Service again under the Lost/Found tab.  Also restart your phone afterwards.
