06-18-2023 09:51 AM - last edited on 06-18-2023 11:08 AM by Dunkman
When I signed up to my plan, I was getting 3 GB + 2 GB bonus for a total of 5 GB. Recently, the 2 GB bonus disappeared - I am only getting 3 GB per month. How do I get this corrected?
06-18-2023 10:32 AM
@openworld Just be sure to change plan for next renewal and not immediately . Or you loose money on your current cycle
06-18-2023 10:31 AM
Thanks
06-18-2023 10:30 AM
Thank you
06-18-2023 10:27 AM
@openworld The one I mentioned is the cheapest 4G option
06-18-2023 10:27 AM
@openworld the $44 for 30 GB is the best deal on the market now. If you are willing to go with 90 days, it will be down to $39 a month!! But you will have to pay 3 months price upfront ($39x3 = $117) and PM will also give you the whole 3 months data (90 GB) on day 1 for you to use it for the next 90 days
06-18-2023 10:25 AM
Thank you.
Which 4G data promo plan do you recommend?
06-18-2023 10:17 AM
06-18-2023 10:17 AM
@openworld this is based on your participation and PM has a secret formula to rank it and give out 1/2/5/10/15 points or dollars. The rewards will be deposit in points (Public Points system) at around 8th to 15th of the following month
06-18-2023 10:16 AM
@openworld Community rewards are based on participation , reading learning and helping and sharing with others . And good things will happen
06-18-2023 10:15 AM
How do I get community rewards?
06-18-2023 10:14 AM
Thank you for the explanation.
06-18-2023 10:14 AM
06-18-2023 10:14 AM
@openworld Yes they will remain you pay $117 for 90 day with 90GB of data . At The end of 90 day you will have earned 90 days worth of rewards to use towards the following renewal
06-18-2023 10:11 AM
So do refer friend rewards, autopay rewards, and loyalty rewards remain as a discount every month?
06-18-2023 10:11 AM
@openworld Yes at the end of the 90 days you will have 3x rewards . But when you first sign up to your first 90 days you just get 1x reward for your last 30 day of earned reward
06-18-2023 10:10 AM
@openworld wrote:I signed up August 2021. I pay $35, less $3 rewards for a total of $32 per month.
Founds your promo:
Did your plan go inactive for any reason? Then you will lose the ongoing 2GB data add on.
If not, you could contact CSA to see what happened. Or you could switch to the new 4G data promo plan. You will keep your old rewards.
06-18-2023 10:09 AM
06-18-2023 10:06 AM - edited 06-18-2023 10:06 AM
06-18-2023 10:04 AM
If I sign up to this, do I lose my rewards?
06-18-2023 10:04 AM
06-18-2023 09:58 AM
When did you sign up for your plan? I have a feeling that this promo data was only for a certain number of months. How much are you paying? There might be better deals at the present time with higher speed data.
06-18-2023 09:56 AM
@openworld Also if your not already aware there’s a $39 30GB 90 day plan that expires tomorrow so pay $117 for 90 days with 90 GB of data
06-18-2023 09:53 AM
@openworld You sure this bonus data wasn’t for just x amount of months ? But if somthing is not right please
Message support directly
