10-26-2022 11:06 AM
My friend lost access to his account. His login information has not changed but the system ask to verify that this is him and he cannot complete the required steps. All he wants to do is change his credit card information so that he will regain access to his public mobile services. Can he be granted access to his account without this extra step? Thanks in advance for your help with this.
My Account
10-27-2022 01:16 AM
To explain what the above mentioned vouchers can do, or also using real time payments in some stores, is that it reactivates the account. Then the SMS option can be used to login and change the credit card.
This is assuming the account is suspended.
10-27-2022 12:04 AM - edited 10-27-2022 12:06 AM
Unfortunately there are no way of accessing your account without all the credentials.
He will need to answer all the security questions and his PIN. This is the only prevention of SIM Swapping.
The only other option is to purchase vouchers and dial 611 at these locations:
10-26-2022 11:17 AM
Your friend has to contact agent to gain access to his account.
To Contact CSA-agent; there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
10-26-2022 11:16 AM - edited 10-26-2022 11:17 AM
@yvandas hi there is no bypassing steps for security reasons get him to try a different browser in secret or ingognito mode and try to login again if that doesn't work
he needs to contact a customer service agent
1. you can open a ticket through Simon here https://publicmobile.ca/chatbot.
2. alternatively you can private message them here
