08-27-2020 12:25 AM - edited 01-05-2022 12:56 PM
Today I loss service for about 4 hours. I shut down the phone and restated it and my service resumed. Why did this happen ?
Edited by Moderator to remove content that violates Terms of Service.
Phones
08-27-2020 04:59 PM
I'm happy to hear you resolved your issue. If you feel a member answered your question then accept a solution from them. It counts towards their community reward. As do do bravos so anyone else that was helpful you can bravo as well.
FYI.....to reply to someone specific you can tag them. Use the "@" key and a pop up box will appear with the recent posting members names in it just tap or click on their name to fill out your tag. Alternatively off their name doesn't appear just type it out after the "@" followed by a space and it should appear in the pop up box for you to click on.
08-27-2020 01:49 PM
08-27-2020 01:47 PM
Thank you for your words of wisdom. So correct
08-27-2020 08:15 AM
@2seniors My phone reminds me to restart if I haven't done it in the past 7 days. As stated, your phone is a computer, it's a good idea to restart once in awhile.
08-27-2020 07:50 AM
@pankajjoshi put it in aeroplane mode for 5 minutes, take it off and restart your phone. Stay safe.
08-27-2020 07:29 AM
seems like service or power outage even mine service is slow but comes on ..
08-27-2020 05:10 AM - edited 08-27-2020 05:10 AM
Your smartphone is a computer. Computers need a periodic reboot and smartphones are no different. Above article gives a good explanation.
08-27-2020 12:45 AM
@2seniors there might of been a service outage in the area and restarting your device reset the network. you can check this website to see if your area was affected
08-27-2020 12:41 AM
@2seniors wrote:Today I loss service for about 4 hours. I **bleep** down the phone and restated it and my service resumed. Why did this happen ?
Is this the only screen you have? Do you have a tablet? A laptop? A desktop? Do you keep them all on? Do you fully power off your phone at all? Frequently?
Software and system memory and the CPU and the operating system that keeps it all together gets muddled up often.
Rebooting sets everything back to the startup mode. Not factory reset. Not reset. Just reboot.
08-27-2020 12:34 AM
You will be surprised when you reboot any device on what it fixes and resets.
