03-25-2023 02:30 PM
Hi I used to have lte on my phone each month now it’s been a while since I have no more lte. Can someone help me ?
03-25-2023 03:40 PM
H @adibahjbili69 what makes you think you have no more LTE?
You only see 4G on the phone? if it is 4G, it's ok, 4G=LTE
If you only see H or H+ or 3G, maybe you have change the network type to 3G only. You can change it back to Automatic on your phone network settings
03-25-2023 02:44 PM
@adibahjbili69 wrote:Hi I used to have lte on my phone each month now it’s been a while since I have no more lte. Can someone help me ?
@adibahjbili69 , please try these steps & see if it helps:
Turn off your phone, remove your sim card from your phone for 5 minutes, put sim card back in your phone & turn phone back on. Reset your network settings (it will also remove your wifi & bluetooth settings so you’ll need to add those again after reboot) & reboot your phone if it doesn’t automatically.
Make sure as per @DennyCrane suggestion that your network is set to Auto or LTE depending on which device settings you have.
Please let us know how that goes.
03-25-2023 02:33 PM
Are you referring to data or phone calls (VoLTE)? If the former, check your network settings and make sure it's set to auto or LTE preferred.
