Looking for 3 month subscription option on 5g 20gb $34 plan.
02-07-2024
05:28 PM
02-07-2024
09:48 PM
computergeek541
Currently on 1 month subscription for 5g 20gb plan at $34. I would like to do the 3 month subscription to get $5/month off. The option for 3 month subscription is not available.
Plans
02-07-2024 06:36 PM
You can request the customer support agents to consider moving to a 90-day plan for a $5 'discount'.
They may or may not provide this if the plan you're interested in may have once had that option.
It's worth an ask, just don't expect it:
To contact a Customer Support Agent, send a private message to them by clicking here. You’ll need to be logged into your Community account for the link to work.
Watch for their response in your Community private mailbox which will be indicated by a number on the small envelope icon to the left of your Community avatar, or tap your Avatar down in Messages.
02-07-2024 05:39 PM
Thanks! That makes sense!
02-07-2024 05:35 PM - edited 02-07-2024 05:36 PM
@WillW There's this one although you wouldn't save $5, depends if you'd also like more data. Only certain plans have a 90 day option.
02-07-2024 05:32 PM - edited 02-07-2024 05:33 PM
Yes, Some 90-ays are still there: I used computer to see these Plans...
What might be incorrect is price per MONTH. Unless PM changed something it is per 30 DAYS and not MONTH
