11-17-2020 09:40 PM - edited 01-05-2022 04:09 PM
11-18-2020 05:49 PM
@botb1314 wrote:The exit code is 011
Exit codes do not need to be used. While 011 will usually work, + and then the country code will suffice.
11-18-2020 11:36 AM
11-17-2020 11:51 PM
@botb1314 wrote:Please Help
I brought the 500 min hong kong, china, it does not work. 6ut1 error or you do not have voice.
Does your plan include phone calls? A long distance add-on cannot be used if you are on a data-only price plan.
11-17-2020 09:44 PM
11-17-2020 09:42 PM - edited 11-17-2020 09:43 PM
Log into self service to confirm the add on is there. It is a 2 step process. You added the funds now go back in and make the purchase.
