Long distance charges
CandyCane2024
I have a CAN-US plan.
Can I call to the US from Canada without paying for long distance?
If you have experience doing that, please share your experience.
thanks in advance
@chimo48 wrote:
i had this same question and support said it wasnt included however im not convinced.  wouldn't there be a long distance charge in my account?
Public Mobile doesn't have pay-per-use charges.
chimo48
will13am
@CandyCane2024 , calls to Canada or US is done the same way.  When calling the US, expect to hear a message about long distance charges may apply.  Of course you don't need to worry about the notification.  Just for fun call 804-222-1111 (Richmond VA), it is a testcall.com number that you can use to do tests like voice echo test, 1000 Hz tone, etc.
eddieO
Yes, you can call the US freely as if it was a Canadian number and when in the US you can continue to use the plan as if you were in Canada including calling back to Canadian numbers
